| TMP8803CSN引脚功能资料 二:引脚功能如下: NO. Pin name I/O Function 1 BAND1 Out BAND data output 1 2 BAND2 Out BAND data output 2 3 KEY In Key input 4 VSS - GND connection 5 RESET In Reset signal input 6 XIN In 8 MHz oscillator connecting 7 XOUT Out 8 MHz oscillator connecting 8 TEST In GND connection 9 VDD In 5V power supply 10 VSS - GND connection 11 VSS - GND connection 12 FBP in In Input terminal for FBP 13 H out Out Output terminal for Horizontal driving pulse 14 HAFC 1 - Terminal To be connected capacitor for H AFC filter 15 V saw - Terminal To be connected capacitor to generate Vsaw signal 16 V out Out Output terminal for Vertical driving pulse 17 HVcc - Vcc terminal for DEF circuit 18 NC - 19 Cb in In Input terminal for Cb signal 20 Y in In Input terminal for Y signal 21 Cr in In Input terminal for Cr signal 22 TV DGND - GND terminal for Digital block 23 C in In Input terminal for Chroma signal 24 V2 in In Input terminal for Video signal 25 TV DVcc - Vcc terminal for Digital block 26 V1 in In Input terminal for Video signal 27 ABCL In Input terminal for ABL/ACL control 28 AU out Out Output terminal for Audio signal |
GMT+8, 2025-12-31 16:48 , Processed in 0.214830 second(s), 20 queries .
