查看: 219|回复: 0
路由器的默认网关怎么设置(路由器网关ip怎么设置)
发表于 2023-5-13 02:39:11 | 显示全部楼层 |阅读模式
路由器怎么设置 路由器全部怎么安装 路由器怎么设置 路由器亮红灯什么原因 路由器登录入口和光猫的区别 路由器怎么重启 路由器怎么连接 路由器桥接教程详细 路由器干什么用:路由器的默认网关怎么设置路由器网关ip怎么设置
一、路由器的默认网关怎么设置工具/原材料
win10电脑。
1、打开电脑在控制面板主界面内找到并点击“网络和共享中心”;
/iknow-pic.cdn.bcebos.com/79f0f736afc37931e3a3b16ae5c4b74542a911ad"target="_blank"title="点击查看大图"class="ikqb_img_alink">/iknow-pic.cdn.bcebos.com/79f0f736afc37931e3a3b16ae5c4b74542a911ad?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_600%2Ch_800%2Climit_1%2Fquality%2Cq_85%2Fformat%2Cf_auto"esrc="https://iknow-pic.cdn.bcebos.com/79f0f736afc37931e3a3b16ae5c4b74542a911ad"/>
2、点击进入网络和共享中心以后,在左边点击“更改适配器设置”的命令;
/iknow-pic.cdn.bcebos.com/7e3e6709c93d70cf95c09c4ef6dcd100baa12bbe"target="_blank"title="点击查看大图"class="ikqb_img_alink">/iknow-pic.cdn.bcebos.com/7e3e6709c93d70cf95c09c4ef6dcd100baa12bbe?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_600%2Ch_800%2Climit_1%2Fquality%2Cq_85%2Fformat%2Cf_auto"esrc="https://iknow-pic.cdn.bcebos.com/7e3e6709c93d70cf95c09c4ef6dcd100baa12bbe"/>
3、在出现的界面中鼠标右键网络选择“属性”的命令;
/iknow-pic.cdn.bcebos.com/8435e5dde71190ef0f81a49cc01b9d16fdfa607e"target="_blank"title="点击查看大图"class="ikqb_img_alink">/iknow-pic.cdn.bcebos.com/8435e5dde71190ef0f81a49cc01b9d16fdfa607e?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_600%2Ch_800%2Climit_1%2Fquality%2Cq_85%2Fformat%2Cf_auto"esrc="https://iknow-pic.cdn.bcebos.com/8435e5dde71190ef0f81a49cc01b9d16fdfa607e"/>
4、在窗口中找到并双击“Internet协议版本(TCP/IPv4)”的功能;
/iknow-pic.cdn.bcebos.com/8326cffc1e178a8248c449e3f803738da877e8fd"target="_blank"title="点击查看大图"class="ikqb_img_alink">/iknow-pic.cdn.bcebos.com/8326cffc1e178a8248c449e3f803738da877e8fd?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_600%2Ch_800%2Climit_1%2Fquality%2Cq_85%2Fformat%2Cf_auto"esrc="https://iknow-pic.cdn.bcebos.com/8326cffc1e178a8248c449e3f803738da877e8fd"/>
5、点击进入以后,勾选“使用下面的IP地址”就可以对默认网关根据需要进行设置。
/iknow-pic.cdn.bcebos.com/3b87e950352ac65c5e385730f5f2b21193138ab7"target="_blank"title="点击查看大图"class="ikqb_img_alink">/iknow-pic.cdn.bcebos.com/3b87e950352ac65c5e385730f5f2b21193138ab7?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_600%2Ch_800%2Climit_1%2Fquality%2Cq_85%2Fformat%2Cf_auto"esrc="https://iknow-pic.cdn.bcebos.com/3b87e950352ac65c5e385730f5f2b21193138ab7"/>
二、路由器网关ip怎么设置IP地址是IP协议提供的一种统一的地址格式,它为互联网上的每一个网络和每收到其他维修同行的一台主机分配一个逻辑地址,以此来屏蔽物理地址(每个机器都有一个编码,如MAC上就有一个叫MAC地址的东西)的差异。如下是我给大家整理的.,希望对大家有所作用。
  1、登录路由器,在浏览器中输入路由器的LAN口的IP地址,在弹出的对话框中填写路由器的管理用户名和密码后进入管理页面。
  若路由器为默认设置,则其管理地址为192.168.1.1,用户名与密码均为admin(可以在路由器背后的说明上面找到)
  2、登陆路由器成功以后, 在左边框中选择“网络参数”→“WAN口设置”,然后在右边框中的“WAN口连接类型”选择“PPPoE”。“上网账号”和“上网口令”中填入宽带账户的用户名和密码。
GMT+8, 2025-10-16 19:44 , Processed in 0.269483 second(s), 21 queries .
