查看: 436|回复: 0
Eclipse启动Tomcat时报Error loading WebappClassLoader错误的解决方法
发表于 2023-6-4 17:18:47 | 显示全部楼层 |阅读模式
context: /jsf2nd
  delegate: false
  repositories:
    /WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@1172e08
javax.faces.webapp.FacesServlet
java.lang.ClassNotFoundException: javax.faces.webapp.FacesServlet
    at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
    at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
    at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1128)
    at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1026)
    at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4421)
    at org.apache.catalina.core.StandardContext.start(StandardContext.java:4734)
    at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
    at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
    at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
    at org.apache.catalina.core.StandardService.start(StandardService.java:525)
    at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
    at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
2011-12-8 9:11:27 org.apache.catalina.core.StandardContext loadOnStartup
严重: Servlet /jsf2nd threw load() exception
网上搜了几种解决方案:
1、关掉myeclipse,把原来的tomcat换掉,如果是安装版的就卸载,重新放一个tomcat,启动myeclipse,配置tomcat,部署,再启动tomcat,一切OK。
2、之前jar包我是通过Build path -> Configure build path-> Add External JARs的方式添加的,程序编译,Tomcat启动都很正常,没有错误。可是一访问jsp页面就报上述错误。 苦思不得其解,但看了错误信息说是找不到org.springframework.web.servlet.DispatcherServlet类,所以我就干脆将spring.jar,spring-webmvc.jar等jar包通通手工添加到/WEB-INF/lib目录下,并且将default output folder值改为projectName/WebContent/WEB-INF/classes 题目就得以解决了。
这两种解决方案试了都不行,但是大体了解到可能是jar包没有导入进去,所以进了eclipse的工程目录,找到对应的存放jar包的目录:.metadata\.plugins\org.eclipse.wst.server.core\tmp3\wtpwebapps\jsf2nd\WEB-INF\lib,发现果然少了两个jar包,将之放入后题目就解决了。
错误原因:至今未能查明究竟是哪个地方出错了才使得eclipse不能将jar包放到eclipse的tomcat插件下面。
可能的几个原因:
1、我的eclipse选择的默认编译是jdk1.5,而这个项目用的是Tomcat6,
2、我的Eclipse里面默认设置的tomcat的编译器也是1.5
GMT+8, 2025-11-2 04:06 , Processed in 0.282115 second(s), 21 queries .
