查看: 389|回复: 0
华为路由器的NAT配置(华为路由器基本配置)
发表于 2023-5-13 19:36:26 | 显示全部楼层 |阅读模式
路由器怎么设置 路由器全部怎么安装 路由器怎么设置 路由器亮红灯什么原因 路由器登录入口和光猫的区别 路由器怎么重启 路由器怎么连接 路由器桥接教程详细 路由器干什么用:华为路由器的NAT配置华为路由器基本配置
一、华为路由器的NAT配置
华为路由器 NAT及DHCP配置实例
sysname HUAWEI-AR28-11
nat address-group 1 125.95.190.3 125.95.190.3
nat static 192.168.100.254 125.95.190.6
nat static 192.168.100.252 125.95.190.5
nat aging-time tcp 360
radius scheme system
domain system
local-user admin
password cipher .]@USE=B,53Q=^Q`MAF4<1!!
service-type telnet terminal
level 3
service-type ftp
dhcp server ip-pool 1
network 192.168.1.0 mask 255.255.255.0
gateway-list 192.168.1.1
dns-list 202.96.128.86 202.96.128.166 202.96.128.143
dhcp server ip-pool 2
network 192.168.2.0 mask 255.255.255.0
gateway-list 192.168.2.1
dhcp server ip-pool 3
network 192.168.3.0 mask 255.255.255.0
gateway-list 192.168.3.1
dhcp server ip-pool 4
network 192.168.4.0 mask 255.255.255.0
gateway-list 192.168.4.1
dhcp server ip-pool 5
network 192.168.5.0 mask 255.255.255.0
gateway-list 192.168.5.1
dhcp server ip-pool 6
network 192.168.6.0 mask 255.255.255.0
gateway-list 192.168.6.1
dhcp server ip-pool 7
network 192.168.7.0 mask 255.255.255.0
gateway-list 192.168.7.1
acl number 2500
rule 0 permit source 192.168.0.0 0.0.255.255
acl number 3900
rule 0 deny tcp destination-port eq 8
rule 1 deny tcp destination-port eq 135
rule 2 deny tcp destination-port eq 139
rule 3 deny tcp destination-port eq 445
rule 4 deny tcp destination-port eq exec
rule 5 deny tcp destination-port eq 64444
rule 6 deny tcp destination-port eq 8080
rule 7 deny udp destination-port eq 135
rule 8 deny udp destination-port eq 445
rule 9 deny udp destination-port eq 3500
interface Aux0
async mode flow
interface Ethernet0/0
ip address 125.95.190.2 255.255.255.248
nat outbound static
nat outbound 2500 address-group 1
interface Ethernet0/1
description line to HUAWEI-S3928
ip address 192.168.8.2 255.255.255.0
interface Serial0/0
clock DTECLK1
link-protocol ppp
ip address dhcp-alloc
interface NULL0
dhcp server forbidden-ip 192.168.100.252
dhcp server forbidden-ip 192.168.100.254
ip route-static 0.0.0.0 0.0.0.0 125.95.190.1 preference 60
ip route-static 192.168.1.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.2.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.3.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.4.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.5.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.6.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.7.0 255.255.255.0 192.168.8.1 preference 60
ip route-static 192.168.100.0 255.255.255.0 192.168.8.1 preference 60
user-interface con 0
user-interface aux 0
set authentication password cipher V_$D$4N:*#F/$ATR*`+,;!!!
idle-timeout 2 0
user-interface vty 0 4
user privilege level 3
idle-timeout 2 0
return
具体最好咨询厂家
二、华为路由器基本配置
H3C路由器常用基本配置命令       [Quidway]sysname router_name 命名路由器(或交换机)   [Quidway]delete 删除Flash ROM中的配置   [Quidway]save 将配置写入Flash ROM   [Quidway]interface serial 0 进入接口配置模式   [Quidway]quit 退出接口模式到系统视图   [Quidway]shutdown/undo shutdown 关闭/重启接口    [Quidway]ip address ip_address subnet_mask 为接口配置IP地址和子网掩码   [Quidway]display version 显示VRP版本号    [Quidway]display current-configuration 显示系统运行配置信息   [Quidway]display interfaces 显示接口配置信息   [Quidway]display ip routing 显示路由表   [Quidway]ping ip_address 测试网络连通性    [Quidway]tracert ip_address 测试数据包从主机到目的地所经过的网关   [Quidway]debug all 打开所有调试信息   [Quidway]undo debug all 关闭所有调试信息   [Quidway]info-center enable 开启调试信息输出功能   [Quidway]info-center console dubugging 将调试信息输出到PC    [Quidway]info-center monitor dubugging 将调试信息输出到Telnet终端或哑终端   换机配置命令举例(大括号{}中的选项为单选项,斜体字部分为参数值   [Quidway]super password password 修改特权模式口令   [Quidway]sysname switch_name 命名交换机(或路   [Quidway]interface ethernet 0/1 进入接口视图   [Quidway]quit 退出系统视图    [Quidway-Ethernet0/1]duplex {half|full|auto} 配置接口双工工   [Quidway-Ethernet0/1]speed {10|100|auto} 配置接口速率   [Quidway-Ethernet0/1]flow-control 开启流控制    [Quidway-Ethernet0/1]mdi {across|normal|auto} 配置MDI/MDIX   [Quidway-Ethernet0/1]shutdown/undo shutdown 关闭/重启端口    VLAN基本配置命令(以Quidway S3026为例) [Quidway]vlan 3 创建并进入VLAN配置模式,缺省时系统将    所有端口加入VLAN 1,这个端口既不能被创建也不能被删除。
[Quidway]undo vlan 3 删除一个VLAN    [Quidway-vlan3]port ethernet 0/1 to ethernet 0/4 给VLAN增加/删除以太网接口  [Quidway-Ethernet0/2]port access vlan 3 将本接口加入到指定VLAN id  [Quidway-Ethernet0/2]port link-type {access|trunk|hybrid} 设置端口工作方式,access(缺省)不支持802.1q帧的传送,而trunk支持(用于Switch间互连),hybrid和trunk的区别在于 trunk 只允许缺省VLAN的报文发送时不打标签,而hybrid允许多个VLAN报文发送时不打标签。
端口聚合配置命令    [Quidway]link-aggregation ethernet 0/7 to ethernet 0/10 {ingress|both} 配置端口聚合   Port_num1为端口聚合组的起始端口号,Port_num2为终止端口号
ingress为接口入负荷分担方式,both为接口出负荷分担方式。
STP基本配置命令    [Quidway]stp {enable|disable} 开启/关闭 STP 功能,默认关闭,开启后所有端口都参与STP 计算。
[Quidway-Ethernet0/3]stp disable 关闭指定接口上的STP功能,如某些网络不存在环路可以关闭STP。
PPP配置命令    [Quidway-Serial0]link-protocol ppp 封装PPP协议    [Quidway-Serial0]ppp authentication-mode {pap|chap} 设置验证类型    [Quidway]local-user username password {simple|cipher} password 配置用户列表   - PAP验证配置:   主验证方    [Quidway]local-user username password {simple|cipher} password 配置用户列表   [Quidway-Serial0]ppp authentication-mode pap   被验证方    [Quidway-Serial0]ppp pap local-user username password {simple|cipher} password   - CHAP验证配置:   主验证方    [Quidway]local-user username password {simple|cipher} password 配置被验证方用户列表   [Quidway-Serial0]ppp chap host hostname 配置本地名称   [Quidway-Serial0]ppp authentication-mode chap   被验证方    [Quidway]local-user username password {simple|cipher} password 配置主验证方用户列表   [Quidway-Serial0]ppp chap user username 配置本地名称   MP配置命令    [Quidway-Serial0]ppp mp 封装MP协议    [Quidway]ppp mp user username bind virtual-template number 建立用户与虚拟模板的对应关系   [Quidway]interface virtual-template number 配置虚拟接口模板   [Quidway]ppp mp max-bind number 设置虚拟模板最大绑定数(1-100)   帧中继配置命令    [Quidway-Serial0]link-protocol fr {mfr|ietf|nonstandard} 封装帧中继协议:IETF、Cisco兼容   [Quidway-Serial0]fr interface-type {dte|dce|nni} 配置帧中继接口类型,NNI为帧中继交换机之间的接口。
若配为DCE或NNI,则须先使能fr switching。
[Quidway-Serial0]fr lmi type {q933a|ansi|cisco-compatible} 配置LMI协议类型   [Quidway-Serial0]fr dlci dlci_number 配置一条本地虚电路号    [Quidway-Serial0]fr map {ip|ipx} protocol-address dlci dlci_number 建立本地DLCI到对端协议地址的映射    [Quidway-Serial0]fr inarp [ip|ipx] [dlci_number] 配置Inverse ARP动态映射   [Quidway]interface type number.subinterface_number 创建并进入子接口配置模式   RIP协议配置命令    [Quidway]display rip 显示RIP配置信息   [Quidway]rip 启动并进入RIP配置模式    [Quidway-rip]network {network_number|all} 在指定网络上使能RIP   [Quidway-rip]peer ip_address 配置报文的定点传送    [Quidway-Ethernet0]rip version {1|2 [bcast|mcast]} 指定RIP版本及传送方式
[Quidway-Serial0]rip work 指定接口工作状态(同rip input,rip output)   [Quidway-rip]auto-summary 配置RIP-2路由聚合    [Quidway-Serial0]rip authentication simple password 配置RIP-2明文认证密码    [Quidway-Serial0]rip authentication md5 key-string string 配置RIP-2 MD5密文认证密码串   [Quidway-Serial0]rip authentication md5 type {nonstandard-compatible|usual} 指定MD5类型   [Quidway]debugging rip packet 打开RIP调试开关   [Quidway]info-center console 将调试信息输出到PC   静态路由配置命令    [Quidway]ip route ip_address subnet_mask {interface_name|gateway_address} [preference preference_value] [reject|black_bone]    [命令说明] reject:任何去往该目的地的报文均被丢弃,通知源主机不可达。
black_bone:任何去往该目的地的报文均被丢弃,不通知源主机。
当只有下一跳的接口是PPP或HDLC接口才能写interface_name,如Serial0,否则只能写gateway_address(下一跳地址)。
[命令举例] [Quidway]ip route 129.1.0.0 16 10.0.0.2   [Quidway]ip route 129.1.0.0 255.255.0.0 10.0.0.2   [Quidway]ip route 129.1.0.0 16 Serial2    [Quidway]ip route 0.0.0.0 0.0.0.0 10.0.0.2 配置缺省路由。
OSPF配置命令    [Quidway]router id ip_address 配置Router ID   [Quidway]ospf enable 启用OSPF协议    [Quidway-Serial0]ospf enable area area_id 配置当前接口所属的OSPF区域
GMT+8, 2025-11-6 11:34 , Processed in 0.286523 second(s), 21 queries .
