查看: 261|回复: 0
在路由器上配置ipv6地址(怎么设置路由器的ipv6)
发表于 2023-5-13 19:19:55 | 显示全部楼层 |阅读模式
路由器怎么设置 路由器全部怎么安装 路由器怎么设置 路由器亮红灯什么原因 路由器登录入口和光猫的区别 路由器怎么重启 路由器怎么连接 路由器桥接教程详细 路由器干什么用:在路由器上配置ipv6地址怎么设置路由器的ipv6ipv6路由器怎么设置
一、在路由器上配置ipv6地址
步骤如下啊
R1的配置:
Router>en
Router#en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#no ip do lo
Router(config)#line con 0
Router(config-line)#no exec-t
Router(config-line)#logg s
Router(config-line)#ho R1
R1(config)#ipv6 unicast-routing
R1(config-if)#ipv6 address 2006:bbbb::1/64
R1(config-if)#inter lo1
R1(config-if)#ipv6 address 2007:cccc::1/64
R1(config-if)#inter s2/1
R1(config-if)#ipv6 address 2008:dddd::1/64
R1(config-if)#no shut
*Jul 18 20:01:19.879: %LINK-3-UPDOWN: Interface Serial2/1, changed state to up
*Jul 18 20:01:20.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1, changed state to up
*Jul 18 20:01:48.771: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1, changed state to down
R1(config-if)#exi
*Jul 18 20:04:48.771: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1, changed state to up
R1(config)#ipv6 rout
R1(config)#ipv6 route 2007:aaaa::2/64 s2/1 //静态路由
R1(config)#end
R1#show ipv6 rou
IPv6 Routing Table - 9 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
C   2006:BBBB::/64 [0/0]
via ::, Loopback0
L   2006:BBBB::1/128 [0/0]
via ::, Loopback0
S   2007:AAAA::/64 [1/0]
via ::, Serial2/1  静态路由
C   2007:CCCC::/64 [0/0]
via ::, Loopback1
L   2007:CCCC::1/128 [0/0]
via ::, Loopback1
C   2008DDD::/64 [0/0]
via ::, Serial2/1
L   2008DDD::1/128 [0/0]
via ::, Serial2/1
L   FE80::/10 [0/0]
via ::, Null0
L   FF00::/8 [0/0]
via ::, Null0
R1#ping ipv6 2007:AAAA::2 //通了  哈哈哈哈
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 2007:AAAA::2, timeout is 2 seconds:
R2的配置:
Router>en
Router#conf t
Router(config-line)#ho R2
R2(config-if)#inter lo1
R2(config-if)#ipv6 address 2005:dddd::1/64
R2(config-if)#inter lo0
R2(config-if)#ipv6 address 2007:aaaa::2/64
R2(config-if)#inter s2/1
R2(config-if)#ipv6 address 2008:dddd::2/64
R2(config-if)#no shut
R2(config-if)#exi
R2(config)#ipv6 route ::/0 s2/1 //默认路由
R2#show ipv6 rout
S   ::/0 [1/0]
via ::, Serial2/1  默认路由
C   2005DDD::/64 [0/0]
via ::, Loopback1
L   2005DDD::1/128 [0/0]
via ::, Loopback1
C   2007:AAAA::/64 [0/0]
via ::, Loopback0
L   2007:AAAA::2/128 [0/0]
via ::, Loopback0
via ::, Serial2/1
L   2008DDD::2/128 [0/0]
via ::, Serial2/1
L   FE80::/10 [0/0]
via ::, Null0
L   FF00::/8 [0/0]
via ::, Null0
二、怎么设置路由器的ipv6
简易ipv6操作方法:
1、设置路由器的SSID(即WiFi名)和访问密码;将路由器设置成为自动获取IP地址;
2、关闭路由器的DHCP服务;
3、将入户网线接入路由器的L口。
4、使用笔记本连接该路由器的WiFi,登录ipv6.tsinghua.edu.cn测试是否获得了ipv6地址。
PS:因为紫荆1-13#每个网络端口只能获取一个ipv4和ipv6地址,所以仅有第一个无线设备可以获得ipv4&6地址,第二个无线设备无法连接到此WiFi。
其他自动获取IP地址的楼宇无此限制。
三、ipv6路由器怎么设置
ipv6路由器是怎么设置呢?很多人买了还不知道吧?下面是我给大家整理的 ipv6路由器怎么设置,欢迎阅读。    ipv6路由器怎么设置
首先如果有个无线路由器,那么就先把电源接通,然后插上网线,进线插在wan口(一般是蓝色口),然后跟电脑连接的网线就随便插哪一个lan口啦,做好这些工作后,然后你会看到路由器后面有个地址跟帐号密码,连接好后在浏览器输入在路由器看到的地址,一般是192.168.1.1(当然如果你家是用电话线上网那就还要多准备一个调制调解器,俗称“猫”)
然后进入,输入相应的帐号跟密码,一般新买来的都是admin
确实后进入操作界面,你会在左边看到一个设置向导,进击进入(一般的`都是自动弹出来的)
进入设置向导界面
点击下一步,进入上网方式设置,我们可以看到有三种上网方式的选择,如果你家是拨号的话那么就用PPPoE。
静态IP一般是专线什么的,也可能是小区带宽等,上层没有DHCP服务器的,或想要固定IP的。
因为我拨号所以选择pppoe。
选择PPPOE拨号上网就要填上网帐号跟密码,这个应该大家都明白,开通宽带都会有帐号跟,填进去就OK啦
然后下一步后进入到的是无线设置,我们可以看到信道、模式、安全选项、SSID等等,一般SSID就是一个名字,你可以随便填,然后模式大多用11bgn.无线安全选项我们要选择wpa-psk/wpa2-psk,这样安全,免得轻意让人家破解而蹭网。
下一步就设置成功啦
点击完成,路由器会自动重启,这时候你耐心等待吧。
成功后出现的界面。
GMT+8, 2025-11-7 19:37 , Processed in 0.294011 second(s), 21 queries .
