| problem has been detected and windows has been shut down to prevent damage to your computer Plug and Play detected an error most likely caused by driver error If this is your first time to see this stop error screen, restart your computer. If this screen appears again. Follow these steps Check to make sure any new hardware or SOFtware is properly instalLED. If this is a new installation. Ask your hardware or software manufacturer for any Windows updates you may need to If the problem continues to exist. DISAble or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadow. If you need to use Safe Mode to remove or disable components. Restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode TechnICal information: Stop:0x00000ca(0x00000001.0x82fc9c08.0x82eb2368.0x00000000) 翻译: 一个问题已经被发现和窗户已经关闭,以防止损坏您的计算机 即插即用检测到错误最有可能造成的错误驱动程序 如果这是您第一次看到这种停止错误屏幕,重新启动电脑. 如果这个画面再一次出现. 跟着这些步骤 检查以确保任何新的硬件或软件已正确安装。如果这是一个新的安装。请询问您的硬件或软件制造商的任何Windows更新您可能需要 如果问题继续存在。禁用或删除任何新安装的硬件或软件。禁用的BIOS内存选项,如缓存或阴影。如果你需要使用安全模式删除或禁用组件。重新启动计算机,按F8键选择高级启动选项,然后选择安全模式 |
GMT+8, 2026-1-16 17:54 , Processed in 0.164858 second(s), 16 queries .
