| 测整机高压供电电路C4对地+305V电压,正常;测低压供电电路C92对地+18V电压,正常;测C91对地+5V电压。正常;测比较器U2A(2)脚输出端对地电压为+10V(正常为0.2V)测U2A(5):脚同相输入端对地+3.8V电压上升(正常为+3v)。测U2A(4)脚反相输入端对地电压为+4.7V,正常。比较器U2A(2)脚输出端已由低电平变为高电平。用R×100挡检测发现贴片电容器C13(101)漏电,更换C13后整机恢复正常。 |
GMT+8, 2025-12-10 16:19 , Processed in 0.107843 second(s), 17 queries .
