| 路由器怎么设置 路由器全部怎么安装 路由器怎么设置 路由器亮红灯哪种故障 路由器登录入口和光猫的区别 路由器怎么重启 路由器怎么连接 路由器桥接教程详细 路由器干什么用:路由器怎么设防火墙路由器怎样设置防火墙防火墙路由器作用是什么 一、路由器怎么设防火墙 对于Cisco的防火墙设置基本上不是那么简单的 解答1,开启CBAC,配置嘛,确实很麻烦,不过确实是很有用。 以下是我自己26的全配置,任何包含CBAC和inspect的部分都是有关防火墙的。 CBAC定义审查的协议,ACL定义缺省阻塞的数据。 具体最好参看Cisco文档。 Current configuration : 3448 bytes ! version 12.2 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname C26VPDN ! logging queue-limit 100 enable secret 5 $1$NcbN$W43qLePAdcJtYW/uFbeLr1 ! username ccie secret 5 $1$UH6z$.HRK55iOjXzxJQBnKYU2k/ clock timezone Beijing 8 aaa new-model ! ! aaa authentication login xvty local aaa authentication login nouse none aaa session-id common ip subnet-zero no ip source-route ip cef ! ! no ip domain lookup ! ip inspect one-minute high 1200 ip inspect one-minute low 800 ip inspect tcp max-incomplete host 150 block-time 0 ip inspect name CNC tcp ip inspect name CNC udp ip inspect name CNC icmp ip audit notify log ip audit po max-events 100 vpdn enable ! vpdn-group CNC request-dialin protocol pppoe ! ! ! ! ! ! ! ! ! ! ! ! ! no voice hpi capture buffer no voice hpi capture destination ! ! mta receive maximum-recipients 0 ! ! ! ! interface Ethernet0/0 ip address 192.168.51.26 255.255.255.0 ip nat inside full-duplex pppoe enable pppoe-client dial-pool-number 1 ! interface Serial1/0 no ip address shutdown no fair-queue ! interface Serial1/1 no ip address shutdown ! interface Serial1/2 no ip address shutdown ! interface Serial1/3 no ip address shutdown ! interface Dialer1 mtu 1492 ip address negotiated ip access-group CBAC in ip nat outside ip inspect CNC out encapsulation ppp dialer pool 1 dialer-group 1 ppp pap sent-username sy_xxxxx password 0 xxxxx ! ip nat inside source list vpdn interface Dialer1 overload ip nat inside source static tcp 192.168.51.101 32323 interface Dialer1 32323 ip nat inside source static udp 192.168.51.101 32323 interface Dialer1 32323 ip nat inside source static tcp 192.168.51.100 11111 interface Dialer1 11111 ip nat inside source static udp 192.168.51.100 11111 interface Dialer1 11111 ip nat inside source static udp 192.168.51.100 3333 interface Dialer1 3333 ip nat inside source static tcp 192.168.51.100 3333 interface Dialer1 3333 ip nat inside source static tcp 192.168.51.100 23232 interface Dialer1 23232 ip nat inside source static udp 192.168.51.100 23232 interface Dialer1 23232 ip nat inside source static udp 192.168.51.101 55555 interface Dialer1 55555 ip nat inside source static tcp 192.168.51.101 55555 interface Dialer1 55555 no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! ! ip access-list standard vpdn permit 192.168.51.0 0.0.0.255 ip access-list standard xvtyacl permit 192.168.51.0 0.0.0.255 ! ip access-list extended CBAC permit icmp any any echo-reply permit icmp any any unreachable permit icmp any any packet-too-big permit icmp any any ttl-exceeded permit icmp any any time-exceeded permit tcp any any eq 55555 permit udp any any eq 55555 permit udp any any eq 32323 permit tcp any any eq 32323 permit tcp any any eq 3333 permit udp any any eq 3333 permit tcp any any eq 11111 permit udp any any eq 11111 permit tcp any any eq 23232 permit udp any any eq 23232 ! dialer-list 1 protocol ip permit priority-list 1 protocol ip high tcp 3333 priority-list 1 protocol ip high udp 3333 priority-list 1 default low ! radius-server authorization permit missing Service-Type call rsvp-sync ! ! mgcp profile default ! dial-peer cor custom ! ! ! ! ! line con 0 login authentication nouse line aux 0 line vty 0 4 access-class xvtyacl in login authentication xvty ! ntp clock-period 17208481 ntp server 192.43.244.18 ! end 解答2,cisco的dhcp功能很恶心,推荐别用了。 因为需要配置成 client-id对应"mac地址.02"…… 解答3,Cisco的路由器就可以做防火墙了,就别卖别的根本没用的东西了。 不知道你是什么地方的人,如果是沈阳的,我可以上门免费帮你调试,别的地方的朋友就没有办法啦~~欢迎联系~ 二、路由器怎样设置防火墙 设置了路由器,等于所有的电脑都开启了防火墙,不需要再开防火墙了 IP地址过滤比较复杂,要看具体用途 IP地址过滤指在网络的适当位置对数据IP包实施有选择的过滤和转发。 过滤的依据由系统事先设定或者根据需要临时确定,具体形式一般是设置一张过滤逻辑表(也称接入控制表),对通过防火墙的IP包的地址、TCP/UDP的Port ID(端口号)及ICMP进行检查,规定哪些数据包可以通过防火墙等等。 只有满足过滤逻辑的数据包才被转发,否则被过滤丢弃。 例如对端口23即Telnet加以限制,可以防止黑客利用不安全的服务对内部网络进行攻击。 三、防火墙路由器作用是什么 防火墙与路由器从功能上看基本相似. 防火墙可以做路由器使用.... 路由器也可以当做防火墙使用... 但从专业的角度来分析.... 路由器做路由最佳路径时也可以做ACL的包过滤 但如果做的ACL条数较多,路由器延迟会很高.... 如果路由器做ACL大于50条可能会死机..... 防火墙也可以做路由选路,比如双WAN口的数据转发...防火墙也要做一定的路由... 但防火墙在做二条网络路由时需要将其中一个ISP作为默认路由来使用.要不防火墙也很卡防火墙一般可以做100条ACL,并且是正常状态....而路由器50条就能死机... 第二个问题... 路由器与网关的区别你可以把网关认为是路由器... |
GMT+8, 2026-1-14 09:06 , Processed in 0.352297 second(s), 16 queries .
