| 一、实验设备 1、PIX515E-UR两台,软件版本:6.3 2、交换机两台 二、拓扑图 三、配置 部分配置省略: PIX Version 6.3(3) interface ethernet0 100full interface ethernet1 100full nameif ethernet0 outs security0 nameif ethernet1 inside security100 ip address outs 192.168.18.201 255.255.255.0 ip address inside 1.1.1.1 255.255.255.0 failover failover ip address outs 192.168.18.202 failover ip address inside 1.1.1.2 failover link inside global (outs) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outs 0.0.0.0 0.0.0.0 192.168.18.1 1 telnet 0.0.0.0 0.0.0.0 inside sho failover信息:在secondary PIX 开始时是primary PIX为active状态,secondary PIX 为standby状态。 pixfirewall# sho fail Failover On Cable status: Normal Reconnect timeout 0:00:00 Poll frequency 15 seconds Last Failover at: 00:49:39 UTC Fri Jan 1 1993 This host: Secondary - Standby Active time: 0 (sec) Interface outs (192.168.18.202): Normal Interface inside (1.1.1.2): Normal Other host: Primary - Active Active time: 1845 (sec) Interface outs (192.168.18.201): Normal Interface inside (1.1.1.1): Normal Stateful Failover Logical Update Statistics Link : inside Stateful Obj xmit xerr rcv rerr General 117 0 137 0 sys cmd 117 0 117 0 up time 0 0 0 0 xlate 0 0 4 0 tcp conn 0 0 16 0 udp conn 0 0 0 0 ARP tbl 0 0 0 0 RIP Tbl 0 0 0 0 Logical Update Queue Information Cur Max Total Recv Q: 0 1 133 Xmit Q: 0 1 117 经过15秒多状态切换过来! 是primary PIX为standby状态,secondary PIX 为active状态。 pixfirewall# sho fail Failover On Cable status: Normal Reconnect timeout 0:00:00 Poll frequency 15 seconds Last Failover at: 01:32:20 UTC Fri Jan 1 1993 This host: Secondary - Active Active time: 15 (sec) Interface outs (192.168.18.201): Normal (Waiting) Interface inside (1.1.1.1): Normal (Waiting) Other host: Primary - Standby Active time: 2580 (sec) Interface outs (192.168.18.202): Normal Interface inside (1.1.1.2): Link Down (Waiting) Stateful Failover Logical Update Statistics Link : inside Stateful Obj xmit xerr rcv rerr General 212 0 230 0 sys cmd 212 0 210 0 up time 0 0 0 0 xlate 0 0 4 0 tcp conn 0 0 16 0 udp conn 0 0 0 0 ARP tbl 0 0 0 0 RIP Tbl 0 0 0 0 Logical Update Queue Information Cur Max Total Recv Q: 0 1 226 Xmit Q: 0 1 212 注:1、在应用层IE浏览器几乎察觉不到切换。 2、实验参考:Cisco PIX Firewall and VPN Configuration Guide, Version 6.3中的Using PIX Firewall Failover部分。 |
GMT+8, 2025-12-19 00:45 , Processed in 0.204071 second(s), 17 queries .
