思科PIX防火墙VPN的配置实例
2023-5-5 13:44| 发布者: 开心| 查看: 79| 评论: 0
摘要: 一、Pix-Pix    PIX Central      Building configuration...   : Saved   :   PIX Version 6.3(3)   in terface ethernet0 auto   interface ethernet1 auto   name ...
    一、Pix-Pix
   PIX Central
     : Saved
     PIX Version 6.3(3)
     nameif ethernet0 outside security0
     nameif ethernet1 inside security100
     enable password 8Ry2YjIyt7RRXU24 encrypted
     passwd 2KFQnbNIdI.2KYOU encrypted
     hostname pix-central
     fixup protocol dns maximum-length 512
     fixup protocol ftp 21
     fixup protocol h323 h225 1720
     fixup protocol h323 ras 1718-1719
     fixup protocol http 80
     fixup protocol rsh 514
     fixup protocol rtsp 554
     fixup protocol sip 5060
     fixup protocol sip udp 5060
     fixup protocol skinny 2000
     fixup protocol smtp 25
     fixup protocol sqlnet 1521
     fixup protocol tftp 69
     names
     !--- This is traffic to PIX 2.
     access-list 120 permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
     !--- This is traffic to PIX 3.
     access-list 130 permit ip 10.1.1.0 255.255.255.0 10.3.3.0 255.255.255.0
     !--- Do not do Network Address Translation (NAT) on traffic to other PIXes.
     access-list 100 permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
     access-list 100 permit ip 10.1.1.0 255.255.255.0 10.3.3.0 255.255.255.0
     pager lines 24
     logging on
     mtu outside 1500
     mtu inside 1500
     ip address outside 172.18.124.153 255.255.255.0
     ip address inside 10.1.1.1 255.255.255.0
     ip audit info action alarm
     ip audit attack action alarm
     pdm history enable
     arp timeout 14400
     !--- Do not do NAT on traffic to other PIXes.
     nat (inside) 0 access-list 100
     route outside 0.0.0.0 0.0.0.0 172.18.124.1 1
     timeout xlate 3:00:00
     timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
     timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
     timeout uauth 0:05:00 absolute
     aaa-server TACACS+ protocol tacacs+
     aaa-server RADIUS protocol radius
     aaa-server LOCAL protocol local
     no snmp-server location
     no snmp-server contact
     snmp-server community public
     snmp-server enable traps
     floodguard enable
     sysopt connection permit-ipsec
     crypto ipsec transform-set myset esp-des esp-md5-hmac
     crypto map newmap 20 ipsec-isakmp
     crypto map newmap 20 match address 120
     crypto map newmap 20 set peer 172.18.124.154
     crypto map newmap 20 set transform-set myset
     crypto map newmap 30 ipsec-isakmp
     crypto map newmap 30 match address 130
     crypto map newmap 30 set peer 172.18.124.157
     crypto map newmap 30 set transform-set myset
     crypto map newmap interface outside
     isakmp enable outside
     isakmp key ******** address 172.18.124.154 netmask 255.255.255.255
     no-xauth no-config-mode
     isakmp key ******** address 172.18.124.157 netmask 255.255.255.255
     isakmp identity address
     isakmp policy 10 authentication pre-share
     isakmp policy 10 encryption des
     isakmp policy 10 hash md5
     isakmp policy 10 group 1
     isakmp policy 10 lifetime 1000
     telnet timeout 5
     ssh timeout 5
     console timeout 0
     terminal width 80
     Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
     : end
     PIX 2
     : Saved
     PIX Version 6.3(3)
     interface ethernet0 auto
     hostname pix2
     names
     !--- This is traffic to PIX Central.
     access-list 110 permit ip 10.2.2.0 255.255.255.0 10.1.1.0 255.255.255.0
     !--- Do not do NAT on traffic to PIX Central.
     access-list 100 permit ip 10.2.2.0 255.255.255.0 10.1.1.0 255.255.255.0
     pager lines 24
     logging on
     mtu outside 1500
     mtu inside 1500
     ip address outside 172.18.124.154 255.255.255.0
     ip address inside 10.2.2.1 255.255.255.0
     no failover
     failover timeout 0:00:00
     failover poll 15
     no failover ip address outside
     no failover ip address inside
     pdm history enable
     arp timeout 14400
     no snmp-server enable traps
     floodguard enable
     crypto map newmap 10 ipsec-isakmp
     crypto map newmap 10 match address 110
     crypto map newmap 10 set peer 172.18.124.153
     crypto map newmap 10 set transform-set myset
     isakmp key ******** address 172.18.124.153 netmask 255.255.255.255
     telnet timeout 5
     ssh timeout 5
     console timeout 0
     terminal width 80
     : end
     PIX 3 Configuration
     : Saved
     PIX Version 6.3(3)
     hostname pix3
     names
     access-list 110 permit ip 10.3.3.0 255.255.255.0 10.1.1.0 255.255.255.0
     access-list 100 permit ip 10.3.3.0 255.255.255.0 10.1.1.0 255.255.255.0
     pager lines 24
     logging on
     mtu outside 1500
     mtu inside 1500
     ip address outside 172.18.124.157 255.255.255.0
     ip address inside 10.3.3.1 255.255.255.0
     no failover
     failover poll 15
     pdm history enable
     arp timeout 14400
     floodguard enable
     telnet timeout 5
     ssh timeout 5
     console timeout 0
     terminal width 80
     Cryptochecksum:aa3bbd8c6275d214b153e1e0bc0173e4
     : end
GMT+8, 2025-11-24 10:45 , Processed in 0.193690 second(s), 17 queries .
