六个基本命令 static:Configure a persistent one-to-one address translation rule by mapping a local IP address to a global IP address. This is also known as Static Port Address Translation (Static PAT). (Configuration mode.) static [(prenat_interface, postnat_interface)] {mapped_address| interface} real_address [dns] [netmask mask] [norandomseq] [connection_limit [em_limit]] show static nameif,Name interfaces and assign security level. (Configuration mode.) nameif hardware_id if_name security_level show nameif /clear nameif interface:Identify network interface speed and duplex. (Configuration mode.) interface hardware_id [hardware_speed] [shutdown] show interface hardware_id [hardware_speed] [shutdown] ip address:Identifies addresses for network interfaces, and enables you to set the number of times the PIX Firewall will poll for DHCP information. (Configuration mode.) ip address if_name ip_address [netmask] ip address outside dhcp [setroute] [retry retry_cnt] ip address if_name pppoe [setroute] ip address if_name ip_address netmask pppoe [setroute] show ip Displays IP addresses assigned to the network interfaces. show ip address if_name dhcp Displays detailed information about the DHCP lease. show ip address if_name pppoe Displays detailed information about the PPPOE connection. global:Create or delete entries from a pool of global addresses. (Configuration mode.) global [(if_name)] nat_id {global_ip [-global_ip] [netmask global_mask]} | interface global [(if_name)] nat_id {{global_ip} [netmask global_mask] | interface} show global nat:Associate a network with a pool of global IP addresses. (Configuration mode.) nat [(if_name)] id address [netmask [outside] [dns] [norandomseq] [timeout hh:mm:ss] [conn_limit [em_limit]]] nat [(if_name)] 0 access-list acl_name show nat route Enter a static or default route for the specified interface. (Configuration mode.) route if_name ip_address netmask gateway_ip [metric] show route conduit.. 联合使用static和conduit命令来只允许http访问。 pixfirewall(config)#static (inside,outside) 192.168.1.101 10.0.1.10 netmask 255.255.255.255 pixfirewall(config)#conduit per tcp any eq www host 172.16.1.1 conduit语法; conduit deny|permit protocol | object-group protocol_obj_grp_id global_ip global_mask | object-group network_obj_grp_id [operator port [port] | object-group service_obj_grp_id] foreign_ip foreign_mask | object-group network_obj_grp_id [operator port [port] | object-group service_obj_grp_id] |
GMT+8, 2025-10-18 21:11 , Processed in 0.271482 second(s), 16 queries .
