华三路由器端口映射
2023-5-1 08:23| 发布者: 开心| 查看: 40| 评论: 0
摘要: 在这篇文章中,我们将介绍华三路由器端口映射的重要性,以及如何应对相关问题和挑战,希望对您有所帮助。本文内容目录一览:1、h3c路由器端口映射方法2、H3C网吧专用路由器端口映射不成功如何维修3、h ...
    在这篇文章中,我们将介绍华三路由器端口映射的重要性,以及如何应对相关问题和挑战,希望对您有所帮助。本文内容目录一览:1、h3c路由器端口映射方法2、H3C网吧专用路由器端口映射不成功如何维修3、h3c路由器里如何做UPNP端口映射?4、h3c的路由器怎么设置端口映射5、华三路由器如何映射端口h3c路由器端口映射方法
h3c路由器端口映射方法
    你知道华为路由器怎么设置吗?路由器的端口映射的`方法有哪些?本文介绍了华为3com路由器的端口映射的方法,并且给出了睁宏详细的操作步骤和命令语句,相信看完此文会对具体配置有详细的了解。
    * Copyright(c) 2004-2006 Hangzhou Huawei-3Com Tech. Co., Ltd. *
    * Without the owner''''s prior written consent, *
    * no decompiling or reverse-engineering shall be allowed. *
    Login authentication
    Username:admin
    Password:
     dis int -(预示端口状悉芹册况)
    Ethernet1/0 current state :UP
    Line protocol current state :UP
    Description : Ethernet1/0 Interface
    The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
    Internet Address is 218.206.191.49 ---(找到公网地址的端口)
    IP Sending Frames'''' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e24b-90c1
    Media type is twisted pair, loopback not set, promiscuous mode not set
    100Mb/s, Full-duplex, link type is autonegotiation
    Output flow-control is disabled, input flow-control is disabled
    Output queue : (Urgent queuing : Size/Length/Discards) 0/50/0
    Output queue : (Protocol queuing : Size/Length/Discards) 0/首蠢500/0
    Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
    Last clearing of counters: Never
    Last 300 seconds input rate 76409.96 bytes/sec, 611279 bits/sec, 221.16 packets/sec
    Last 300 seconds output rate 169645.62 bytes/sec, 1357165 bits/sec, 217.84 packets/sec
    Input: 84913558 packets, 1899317081 bytes, 84913558 buffers
    1556505 broadcasts, 124223 multicasts, 0 pauses
    374 errors, 0 runts, 0 giants
    0 crc, 0 align errors, 374 overruns
    0 dribbles, 0 drops, 0 no buffers
    Output:73691649 packets, 1323897889 bytes, 73691649 buffers
    19084 broadcasts, 0 multicasts, 0 pauses
    0 errors, 0 underruns, 0 collisions
    0 deferred, 0 lost carriers
     sys --(步入体系视图)
    [H3C]int e1/0
    [H3C]nat server protocol tcp global 218.206.191.49 www inside 192.168.1.96 www
    [H3C]nat server protocol tcp global 218.206.191.49 22 inside 192.168.1.96 22
    [H3C]nat server protocol udp global 218.206.191.49 snmp inside 192.168.1.96 snmp
    [H3C]nat server protocol udp global 218.206.191.49 snmptrap inside 192.168.1.96 snmptrap --(一看就大白tcp/udp是以及谈,www是80,snmp以及snmptrap是161.162端口)
    [H3C]dis thellos
    interface Ethernet1/0
    ip address 218.206.191.49 255.255.255.248
    firewall packet-filter 3000 inbound
    nat outbound 3001 --(这是客户上彀用的地址池不消管,其它的就是端口照射了)
    nat server protocol tcp global 61.178.77.9 www inside 192.168.1.96 www
    nat server protocol tcp global 61.178.77.9 22 inside 192.168.1.96 22
    nat server protocol udp global 61.178.77.9 snmp inside 192.168.1.96 snmp
    nat server protocol udp global 61.178.77.9 snmptrap inside 192.168.1.96 snmptrap
    思科网络的端口照射原理是同样的号令纷歧样罢了,这搭只给出配备布置。
    思科网络en
    思科网络#config t
    思科网络(config)Ip nat inside source static tcp 192.168.1.96 80 218.206.191.49 80
    思科网络(config)Ip nat inside source static tcp 192.168.1.96 22 218.206.191.49 22
    思科网络(config)Ip nat inside source static tcp 192.168.1.96 161 218.206.191.49 161
    思科网络(config)Ip nat inside source static tcp 192.168.1.96 162 218.206.191.49 162H3C网吧专用路由器端口映射不成功如何维修
一、首先检查内网服务是否正常;
在内网通过服务器的内网IP地址,测试是否可以访问对应的服务。若是内网都无法正常访问,建议您排查内网原因,如:该主机配置是否正确,内网客户机是否可以正常Ping通该主机,务必确保提供服务主机可以正常连接互联网。
二、检查外网地址是否有限制;
不经过路由器,将服务器直接连接外网线路上网,测试外明猜银网是否可以访问。如果无法访问,可能网络运营商封锁了需要映射的端口,外网无法访问映射的端口,请向运营商咨询了解。
三、确认网吧路由器设置是否正常:
1.首先,请检查端口映射的配置是否正确。端口映射具体配置请参看《网吧路由映射的激宴具体操作步骤》
确认配置正确后,可以在基础设置-基本选项中,打开端口回流,在内网通过外网IP地址(外网IP地址在系统状态→网络接口中查询),测试映射端口是否可以访问。
2.网络安全→攻击防御→外网防御→禁止外部开放端口保护→禁止阻断外网请求→保存
3.请在系统工具》管理选项里面查看确认路由器的端口是否与映射端口冲突
4.如果外网为双线接入,请检查访问的外网IP地址是否和相兆正应的映射线路对应。或者用户是否做了源地址路由把此服务器调至另一条线路而与映射线路不在一条线路。
5.如果外网为单线接入,请检查是否作了NAT一对一把相应外网接口IP地址占用,造成端口映射不成功。
四、其他
1.保证以上步骤无误如还不成功,请尝试把服务器上的杀毒软件以及防火墙关闭。
2.如果外网检查指定端口已映射成功,但仍不能访问,请尝试使用NAT一对一功能映射服务器上的所有端口,确认是否还有其它端口需要映射。
h3c路由器里如何做UPNP端口映射?
方法:\x0d\x0a这个是上网的映射\x0d\x0a1、nat address-group 1 X.X.X.X X.X.X.X(公网地址)\x0d\x0a 运兆 2、写ACL,比如3001\x0d\x0a3、在连接外网接口下写绝备nat outbound 3001 address-group 1\x0d\x0a端口映射就在外网接口里面写\x0d\x0anat server protocol tcp global X.X.X.X 8080 inside 192.168.100.1 8080    (XXXX是公网地址并悄毁)h3c的路由器怎么设置端口映射
设置映射端口如下:
ADSL网络环境下,使用H3C的朋雀告友在做端口映射的时候,如果用web界面配顷悉明置,把nat打开,选择内部服务器,接口选择连接wan口的eth0/0,协议,tcp,外部地址选择当前接口ip(adsl拨号,没有固定ip)内部地址192.168.*.* 内部端口也填上,确定。然后发现外网地址是0.0.0.0。
adsl拨号虽然连接在eth0/0上,但是它用的是虚拟拨号。可是在接口选项那里没有那一个虚拟拨号接口,如何维修,只好用命令了,好了,那这个命令怎么写。
首先,进入telnet,先看看虚陆悉拟拨号的接口是什么,进入系统视图后,输入
[h3c]dis ip int b(查看各端口状态)
找到一个dialerX(X代表一个数值)的端口,这里以dialer11为例,
也就是dialer11是虚拟拨号接口,那好,我们就进入这个接口视图,输入
[h3c]int dialer11
[h3c-dialer11]
下面就可以输入端口映射的命令了:nat server protocol tcp global current-interface 1433(可改成实际端口号) inside 192.168.0.2 1433
这样就把内网192.168.0.2机器的1433端口映射出去了。华三路由器如何映射端口
1、。在电脑上打开浏览器,进入192.168.1.1这个IP地址,页面会提示你登录,你的用户名和密码伍山都为admin,登录即可。
2、登录进入之后,先点击左边的高级设置,再点击高级设置下面的地址转换,然后进入虚拟服务器。具体如图。
3、点击并进入页面下面的新增,如图就进入了设置界面,世吵具体填写可如图,或者根据自己的实际需求来填写。
4、设置填写完成并确认之后再一次查看页面,就会出现如图一样新加的条目。一系列步骤之腔返中后,映射端口就完成了。
我们鼓励您尝试这些技巧,并发现它们如何帮助您更好地管理和优化您的网络连接。
GMT+8, 2026-1-13 20:10 , Processed in 0.130073 second(s), 16 queries .
