| 在本文中,我们将探讨三层交换机启动路由的一些基础知识,同时也会介绍一些与三层交换机启动路由相关的三层交换机实现路由内容,希望能够为您提供帮助。本文内容目录一览:1、华为三层交换机如何开启路由器功能?2、在三层交换机和路由器上,启动路由功能的命令是什么?3、怎么在三层交换机启用vlan路由?4、三层交换机启用路由功能华为三层交换机如何开启路由器功能? 华为的和扒斗三层交换机默认是打开路由功能的,需唤磨要做的是把VLAN和地址规划了 划分VLAN,并描述 vlan 1 description local-S3600 vlan 2 description link-to-wenquan vlan 3 description link-to-ruzhou vlan 4 description link-to-xiaotun vlan 5 description link-to-baofeng vlan 6 description link-to-pingxi vlan 7 description link-to-pingnan vlan 8 description Uplink-to-Putian vlan 9 description link-to-pingxicentre 给VLAN 划网关 interface Vlan-interface2 description link to wenquan ip address 10.41.77.41 255.255.255.192 interface Vlan-interface3 description link to ruzhou ip address 10.41.77.105 255.255.255.192 interface Vlan-interface4 description link to xiaotun ip address 10.41.77.169 255.255.255.192 interface Vlan-interface5 description link to baofeng ip address 10.41.77.233 255.255.255.192 interface Vlan-interface6 description link to pingxi ip address 10.41.78.41 255.255.255.192 interface Vlan-interface7 description link to pingnan ip address 10.41.78.105 255.255.255.192 interface Vlan-interface8 description uplink to putian ip address 10.41.244.102 255.255.255.252 interface Vlan-interface9 description link to pingxicentre ip address 10.41.80.233 255.255.255.192 给此御VLAN 指定端口 interface Ethernet1/0/2 description link to wenquan port access vlan 2 interface Ethernet1/0/3 description link to ruzhou port access vlan 3 interface Ethernet1/0/4 description link to xiaotun port access vlan 4 interface Ethernet1/0/5 description link to baofeng port access vlan 5 interface Ethernet1/0/6 description link to pingxi port access vlan 6 interface Ethernet1/0/7 description link to pingnan port access vlan 7 interface Ethernet1/0/8 description uplink to putian port access vlan 8 interface Ethernet1/0/9 to Ethernet1/0/24 description link to pingxicentre port access vlan 9 配置路由协议 // (1)用RIP配动态路由 rip network 10.41.77.41 network 10.41.77.105 network 10.41.77.169 network 10.41.77.233 network 10.41.78.41 network 10.41.78.105 network 10.41.80.233 network 10.41.244.102 在三层交换机和路由器上,启动路由功能的命令是什么? 具体拿好得看三层交换机型号,路由器自带路由功能不需要命令去开启吧除非是镇毕数据中心?思科的三层交换机开消旅铅启路由命令是iP routing怎么在三层交换机启用vlan路由? 不同的网段间互访,需要有网关地址,所以你的PC上得配置网关念陪地址,而且昌高亩在交换机上耐森也要配置vlan的地址, 注意:交换机上配置的vlan地址就是网关地址三层交换机启用路由功能 交换机2层以下是普通交换机,只是简单的数据端口之间转发。 三层交换机具备了路由功能,开启路由功能,就具备了像路由器一样的功能,可以使局域网内多台电脑共同通过一个外网ip上网。 三层交换机就是具有部分路由器功能的迹笑交换机,三层交换机的最重要目的是加快大型局域网内部的数据交换,所具有的路由功能也是为这目的服务的,能够做到一次路由,多次转发。 对于数据包转发等规律性的过程由硬件高速实现,而像路由信息更新、路由表巧州春维护、路由计算、路由确定等功能,由软件实现。三层交换技术就是二层交换技术+三层转发技术。 传统交换技术是在OSI网络标准模型第二层--数据链路层进行操作的孝耐,而三层交换技术是在网络模型中的第三层实现了数据包的高速转发,既可实现网络路由功能,又可根据不同网络状况做到最优网络性能。 通过本文中的路由器和WIFI技巧,您可以轻松地保护您的网络,并确保其高效、稳定和安全。 |
GMT+8, 2026-1-13 18:08 , Processed in 0.162174 second(s), 16 queries .
