| 新手设置路由器可能会遇到一些问题,本文h3c路由器端口映射设置将为您提供常见问题的解答和路由器使用技巧。本文内容目录一览:1、h3c路由器端口映射方法2、h3c的路由器怎么设置端口映射3、华三路由器如何映射端口h3c路由器端口映射方法 h3c路由器端口映射方法 你知道华为路由器怎么设置吗?路由器的端口映射的`方法有哪些?本文介绍了华为3com路由器的端口映射的方法,并且给出了睁宏详细的操作步骤和命令语句,相信看完此文会对具体配置有详细的了解。 ************************************************** ****************************** * Copyright(c) 2004-2006 Hangzhou Huawei-3Com Tech. Co., Ltd. * * Without the owner''''s prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ************************************************** ****************************** Login authentication Username:admin Password: dis int -(预示端口状悉芹册况) Ethernet1/0 current state :UP Line protocol current state :UP Description : Ethernet1/0 Interface The Maximum Transmit Unit is 1500, Hold timer is 10(sec) Internet Address is 218.206.191.49 ---(找到公网地址的端口) IP Sending Frames'''' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e24b-90c1 Media type is twisted pair, loopback not set, promiscuous mode not set 100Mb/s, Full-duplex, link type is autonegotiation Output flow-control is disabled, input flow-control is disabled Output queue : (Urgent queuing : Size/Length/Discards) 0/50/0 Output queue : (Protocol queuing : Size/Length/Discards) 0/首蠢500/0 Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0 Last clearing of counters: Never Last 300 seconds input rate 76409.96 bytes/sec, 611279 bits/sec, 221.16 packets/sec Last 300 seconds output rate 169645.62 bytes/sec, 1357165 bits/sec, 217.84 packets/sec Input: 84913558 packets, 1899317081 bytes, 84913558 buffers 1556505 broadcasts, 124223 multicasts, 0 pauses 374 errors, 0 runts, 0 giants 0 crc, 0 align errors, 374 overruns 0 dribbles, 0 drops, 0 no buffers Output:73691649 packets, 1323897889 bytes, 73691649 buffers 19084 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 underruns, 0 collisions 0 deferred, 0 lost carriers sys --(步入体系视图) [H3C]int e1/0 [H3C]nat server protocol tcp global 218.206.191.49 www inside 192.168.1.96 www [H3C]nat server protocol tcp global 218.206.191.49 22 inside 192.168.1.96 22 [H3C]nat server protocol udp global 218.206.191.49 snmp inside 192.168.1.96 snmp [H3C]nat server protocol udp global 218.206.191.49 snmptrap inside 192.168.1.96 snmptrap --(一看就大白tcp/udp是以及谈,www是80,snmp以及snmptrap是161.162端口) [H3C]dis thellos interface Ethernet1/0 ip address 218.206.191.49 255.255.255.248 firewall packet-filter 3000 inbound nat outbound 3001 --(这是客户上彀用的地址池不消管,其它的就是端口照射了) nat server protocol tcp global 61.178.77.9 www inside 192.168.1.96 www nat server protocol tcp global 61.178.77.9 22 inside 192.168.1.96 22 nat server protocol udp global 61.178.77.9 snmp inside 192.168.1.96 snmp nat server protocol udp global 61.178.77.9 snmptrap inside 192.168.1.96 snmptrap 思科网络的端口照射原理是同样的号令纷歧样罢了,这搭只给出配备布置。 思科网络en 思科网络#config t 思科网络(config)Ip nat inside source static tcp 192.168.1.96 80 218.206.191.49 80 思科网络(config)Ip nat inside source static tcp 192.168.1.96 22 218.206.191.49 22 思科网络(config)Ip nat inside source static tcp 192.168.1.96 161 218.206.191.49 161 思科网络(config)Ip nat inside source static tcp 192.168.1.96 162 218.206.191.49 162h3c的路由器怎么设置端口映射 设置映射端口如下: ADSL网络环境下,使用H3C的朋雀告友在做端口映射的时候,如果用web界面配顷悉明置,把nat打开,选择内部服务器,接口选择连接wan口的eth0/0,协议,tcp,外部地址选择当前接口ip(adsl拨号,没有固定ip)内部地址192.168.*.* 内部端口也填上,确定。然后发现外网地址是0.0.0.0。 adsl拨号虽然连接在eth0/0上,但是它用的是虚拟拨号。可是在接口选项那里没有那一个虚拟拨号接口,如何维修,只好用命令了,好了,那这个命令怎么写。 首先,进入telnet,先看看虚陆悉拟拨号的接口是什么,进入系统视图后,输入 [h3c]dis ip int b(查看各端口状态) 找到一个dialerX(X代表一个数值)的端口,这里以dialer11为例, 也就是dialer11是虚拟拨号接口,那好,我们就进入这个接口视图,输入 [h3c]int dialer11 [h3c-dialer11] 下面就可以输入端口映射的命令了:nat server protocol tcp global current-interface 1433(可改成实际端口号) inside 192.168.0.2 1433 这样就把内网192.168.0.2机器的1433端口映射出去了。 华三路由器如何映射端口 1、。在电脑上打开浏览器,进入192.168.1.1这个IP地址,页面会提示你登录,你的用户名和密码伍山都为admin,登录即可。 2、登录进入之后,先点击左边的高级设置,再点击高级设置下面的地址转换,然后进入虚拟服务器。具体如图。 3、点击并进入页面下面的新增,如图就进入了设置界面,世吵具体填写可如图,或者根据自己的实际需求来填写。 4、设置填写完成并确认之后再一次查看页面,就会出现如图一样新加的条目。一系列步骤之腔返中后,映射端口就完成了。 h3c路由器端口映射设置的介绍就聊到这里吧,感谢你花时间阅读本站内容,更多关于h3c路由器端口映射命令、h3c路由器端口映射设置的信息别忘了在家电维修技术论坛学习交流喔。 |
GMT+8, 2026-1-13 06:34 , Processed in 0.177148 second(s), 16 queries .
