vue路由权限
2023-5-1 08:03| 发布者: 开心| 查看: 77| 评论: 0
摘要: 想要了解更多关于vue路由权限和vue路由权限管理的知识吗?那么本文将为您提供全面的介绍和解释,同时还会分享一些实用的技巧和建议。本文内容目录一览:1、vue-element-admin权限路由2、Vue实战篇| ...
    想要了解更多关于vue路由权限和vue路由权限管理的知识吗?那么本文将为您提供全面的介绍和解释,同时还会分享一些实用的技巧和建议。本文内容目录一览:1、vue-element-admin权限路由2、Vue实战篇|使用路由管理用户权限(动态路由)3、vue 项目路由权限管理实现vue-element-admin权限路由
1、java端:
 1.1、通过接口闷唯获取该用户的角色权限
 此处不再复述
 2、没态vue-element
 其主要处理是在这个文件
2.2、permission.js
 import router, {asyncRoutes,constantRoutes }from '@/router'
 import {getAuthMenu }from '@/api/user'
 import Layoutfrom '@/蚂察培layout'
 * Use meta.role to determine if the current user has permission
  * @param roles
  * @param route
 function hasPermission(roles, route) {
 if (route.meta  route.meta.roles) {
 return roles.some(role = route.meta.roles.includes(role))
 }else {
 return true
 * Filter asynchronous routing tables by recursion
  * @param routes asyncRoutes
  * @param roles
 export function filterAsyncRoutes(routes, roles) {
 const res = []
 routes.forEach(route = {
 const tmp = { ...route }
 if (hasPermission(roles,tmp)) {
 if (tmp.children) {
 tmp.children =filterAsyncRoutes(tmp.children, roles)
 res.push(tmp)
 return res
 const state = {
 routes: [],
 addRoutes: [],
 perms: []
 const mutations = {
 SET_ROUTES: (state, routes) = {
 state.addRoutes = routes
 state.routes =constantRoutes.concat(routes)
 ADD_LOGIN_USER_INFO: (state, data) = {
 state.perms = data
 const actions = {
 generateRoutes({ commit }, roles) {
 return new Promise(resolve = {
 const loadMenuData = []
 // 先查询后台并返回左侧菜单数据并把数据添加到路由
       getAuthMenu(roles).then(response = {
 let data = response
 if (response.code !==0) {
 this.$message({
 message:'菜单数据加载异常',
 type:0
 }else {
 const permis = response.pers
 data = response.menuList
 console.log('==============加载===========')
 Object.assign(loadMenuData,data)
 generaMenu(asyncRoutes,loadMenuData)
 const accessedRoutes =asyncRoutes || []
 // accessedRoutes.push({ path: '*', component: () = import('@/views/error-page/404'), hidden: true })
           commit('ADD_LOGIN_USER_INFO',permis)
 commit('SET_ROUTES',accessedRoutes)
 router.addRoutes(accessedRoutes)
 resolve(accessedRoutes)
  * 后台查询的菜单数据拼装成路由格式的数据
  * @param routes
 /* export function generaMenu(routes, data) {
 data.forEach(item = {
 let tempUrl = item.url
 if (item.url === null) {
 tempUrl = ''
 const menu = {
 path: item.url === null ? item.ename : item.url,
 component: item.url === null ? Layout : resolve = require([`@/views${tempUrl}`], resolve),
 children: [],
 name: 'menu_' + item.menuId,
 meta: { title: item.name, id: item.menuId, roles: ['admin'], icon: item.icon }
 if (item.list) {
 generaMenu(menu.children, item.list)
 if (item.menuId !== -100) {
 routes.push(menu)
 if (item.state ===0) {
 let typeParentId =''
       if (item.parentId ===0) {
 typeParentId ='noRedirect'
 let tempUrl = item.urlNew
       if (item.urlNew ===null) {
 tempUrl =''
 if (item.parentId !==0  item.urlNew ===null) {
 tempUrl ='/404'
         item.urlNew ='/404'
 let menu = {}
 if (item.Identify ===1) {// 需铺满屏幕(隐藏左侧导航栏)
         menu = {
 path: item.urlNew ===null ? item.ename : item.urlNew,
 hidden: item.type ===2,
 children: [],
 name:'menu_' + item.menuId,
 redirect:typeParentId,
 meta: {title: item.name,id: item.menuId,roles: ['admin'],icon: item.iconNew }
 }else {
 menu = {
 component: item.urlNew ===null ? Layout : resolve = require([`@/views${tempUrl}`], resolve),
 children: [],
 if (item.list) {
 routes.push(menu)
 export default {
 namespaced:true,
 state,
 mutations,
 actions
权限控制是后台管理系统比较常见的需求,如果我们需要对某些页面的添加权限控制的话,那我们可以在路由管理中的权限做一些校验,没有通过权限校验的给出相应的提示或者直接跳转到报错页面。
 跟着我一起来学vue实战篇路由管理权限吧!
 getCurrentAuthority()函数用于获取当前用户权限,一般来源于后台数据
 check()函数用于权限的校验匹配
 isLogin()函数用于检验用户是否登备首录
路由配置元信息meta:{ authority: ["admin"] }
使用to.matched获取跳转路由的全部信息,包括父路由和子路由
 使用lodash中的判高findLast匹配离跳转路由配置权限的元信息
 引入auth.js中check()和isLogin()进行判断掘滚尺是否具有权限或是否已登录
 如果没有权限则给出提示信息后跳转到403页面,未登录则返回登录页面
运行结果
 当getCurrentAuthority()函数返回admin时,则菜单会显示所有元信息meta:{ authority: ["admin"] }的路由菜单;
 如返回值为user时,菜单会显示所有元信息meta:{ authority: ["user"] }的路由菜单
接下来CrabFort会带大家一起实现更加精细化的权限设计(权限组件、权限指令)vue 项目路由权限管理实现
项目基于  vue-element-admin  基础之上进行开发,感谢  花裤衩  以及为此项目做出贡献的大佬 [社会社会]!
 路由数据由后端控制,前端调用接口返回数据;前端拿到数据处理成可使用的路由结构,然后渲染到页面。
 为了能提供更多的功能,后端返回的数据结构是在原来菜单结构基础之上有所改动的。
 原路由数据结构:
 后端返回数据结构:
 路由数据采用多级嵌套结构,基本可以满足需求。
 拿到接口返回的数据之后还不能直接使用,需要经过一些处理。
 在本地的开发,新增页面时,为了方便开发,获取到后端返回的数据之后用了一个方法来合并数据:
  temporaryMenuArray  临时路由数组的结构需要跟后端返回的数据结构一致。
 使用  setTemporaryMenu :
 合并完临时的路由之后就开始进行路由的处理了。
 从上面后端返回的数据结构中可以看出,已经和需要处理成的路由很像了,但还是有一些数据没有必要在专门的系统那里维护,所以需要一些其他数据的皮穗没处理:
  routesComponents  为一个手动维护的页面路由文件:
 得到的  userCanUseRouteModules  结构如下:
 上面数据中的  type  为2、3层级的  component  已经被替换成对应页面的路由模块了。
 得到  userCanUseRouteModules  之后,其中 name 为  storeManagement:head  的那一层数据是供头部菜单使用的,其 children 的数据才是需要添加的路由数据:
 此时的  asyncRoutes  只放了默认匹配的路由,这个是需要放在所有路由的最后的:
 至此对路由的处理结束。
 处理路由这一步是放在  router.beforeEach  路由全局前置守卫里的,结合原有的逻辑进行了一些判断处理。
 因为路由数据是由后端数据处理得到的,只包含和挂载了当前用户能有权限访问的部分,没有权燃纳限访问的路由就没有被  router.addRoutes  添加,所以并没有在路由守卫里对每次路由的跳转都进行校族陪验。
不要害怕调整路由器和WIFI设置。使用我们提供的指南和技巧,您可以轻松地自定义您的网络,以满足您的需求。
GMT+8, 2026-1-12 21:56 , Processed in 0.166908 second(s), 16 queries .
