查看: 119|回复: 0
静态路由配置实战,一分钟了解下
发表于 2023-5-12 18:39:23 | 显示全部楼层 |阅读模式
一、静态路由
静态路由是这样的一种路由,它通过人工输入到路由选择表中。二、静态路由优点
1、不需要动态路由选择协议,这减少了路由器的日常开销。
2、在小型互连网络上很容易配置。
五台路由器,划分成三个网段;要求使用静态路由协议,使得路由器之间能够互相通信
帧中继仅了解即可,不作为掌握技术。重点掌握静态路由配置。
1、R1配置:
R1#sh run
Building configuration...
Current configuration : 743 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname R1
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0
ip address 172.16.1.1 255.255.255.0
interface Ethernet1
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.16.2.1 255.255.255.0
encapsulation frame-relay
frame-relay map ip 172.16.2.3 103 broadcast
frame-relay map ip 172.16.2.5 105 broadcast
no frame-relay inverse-arp
ip classless
ip route 172.16.3.0 255.255.255.0 172.16.2.3
no ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
End
R2#sh run
Current configuration:
version 12.0
hostname R2
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no ip directed-broadcast
interface Ethernet0
ip address 172.16.1.2 255.255.255.0
interface Ethernet1
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
no ip http server
ip classless
ip route 172.16.2.0 255.255.255.0 172.16.1.1
ip route 172.16.3.0 255.255.255.0 172.16.1.1
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line aux 0
line vty 0 4
End
R3#sh run
version 12.0
hostname R3
ip subnet-zero
no ip domain-lookup
cns event-service server
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
ip address 172.16.3.3 255.255.255.0
encapsulation ppp
interface Serial1
ip address 172.16.2.3 255.255.255.0
frame-relay map ip 172.16.2.5 301 broadcast
frame-relay map ip 172.16.2.1 301 broadcast
ip classless
ip route 172.16.1.0 255.255.255.0 172.16.2.1
no ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
End
R4#sh run
Current configuration : 798 bytes
version 12.1
no service single-slot-reload-enable
hostname R4
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip domain-lookup
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.16.3.4 255.255.255.0
encapsulation ppp
clockrate 64000
ip kerberos source-interface any
ip classless
ip route 172.16.1.0 255.255.255.0 172.16.3.3
ip route 172.16.2.0 255.255.255.0 172.16.3.3
no ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
End
R5#sh run
version 12.1
hostname R5
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 5.5.5.5 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.16.2.5 255.255.255.0
frame-relay map ip 172.16.2.3 501 broadcast
frame-relay map ip 172.16.2.1 501 broadcast
ip classless
no ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
总结:静态路由配置非常简单,就像地图一样需要管理员手动进行绘制,路由目的地及下一跳,可以理解为到达目的地就必须要到达下一站才能逐跳达到。经过的每一跳路由器都都必须有到达目标的路由和下一跳地址。
GMT+8, 2025-10-10 01:34 , Processed in 0.278831 second(s), 24 queries .
