查看: 424|回复: 0
计算机管理打开报错提示widows找不到文件怎么办
发表于 2023-6-4 17:21:43 | 显示全部楼层 |阅读模式
我们在利用计算机的时候,可以通过右击计算机,选择管理来打开计算机的当地管理,来查看一些计算机的相关信息如磁盘管理、事件查看器等等,但有些用户在进入计算机当地管理时候会出现“widows找不到文件 C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Computer Management.lnk。请确定文件名是否正确后,再试一次”的报错,这是怎么回事呢?我们一起来办理一下。
计算机管理打开错误怎么办?1.复制虚线里边的内容,放入记事本,另存为(**.reg)注册表文件,然后双击导入注册表就可以了。
复制代码代码如下:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage]
@=hex(2):40,00,25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,6f,00,74,\
00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
79,00,63,00,6f,00,6d,00,70,00,75,00,74,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,\
00,34,00,30,00,30,00,00,00
"MUIVerb"=hex(2):40,00,25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,\
6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,6d,00,79,00,63,00,6f,00,6d,00,70,00,75,00,74,00,2e,00,64,00,6c,00,6c,00,\
2c,00,2d,00,34,00,30,00,30,00,00,00
"SuppressionPolicy"=dword:4000003c
"HasLUAShield"=""
[HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage\command]
@=hex(2):25,00,77,00,69,00,6e,00,64,00,69,00,72,00,25,00,5c,00,73,00,79,00,73,\
00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,6d,00,63,00,2e,00,65,00,78,00,\
65,00,20,00,2f,00,73,00,20,00,25,00,77,00,69,00,6e,00,64,00,69,00,72,00,25,\
00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,63,00,6f,00,\
6d,00,70,00,6d,00,67,00,6d,00,74,00,2e,00,6d,00,73,00,63,00,00,00
2.找到以下路径:C:\Windows\System32\compmgmt,将其发送到桌面快捷方式,然后将文件名改为Computer Management(后缀名为lnk),然后将快捷方式移动到C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\目录下即可办理。
计算机管理打开错误怎么办?
GMT+8, 2026-1-28 02:47 , Processed in 0.289239 second(s), 25 queries .
