查看: 1851|回复: 1
创维34SG9000(5P21机芯)受潮引发的故障
1174 小时
2006-5-6
2021-6-10
热心会员常驻会员资深会员勋章
发表于 2008-3-5 10:42 | 显示全部楼层 |阅读模式
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 84pt; mso-char-indent-count: 8.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">创维</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">34SG9000</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">5P21</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">机芯)受潮引发的故障</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 52.5pt; TEXT-INDENT: -52.5pt; mso-char-indent-count: -5.0; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>故障现象:不开机指示灯亮一会儿开机——关机——开机——有雪花点但无台,换频道时出现红屏左全黑至右逐渐黑条变小至屏幕右边全红,随时间增加黑少红多至无,个别频道出现图象——所有频道全部出现图象。</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 52.5pt; TEXT-INDENT: -52.5pt; mso-char-indent-count: -5.0; mso-char-indent-size: 10.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">检修过程:开机时测电源电压正常,测</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CPU</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">42</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">SDA</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">数据线电压</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3.8V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">正常,(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">41</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">SCL</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">时钟线电压在开机时</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">4.0V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">正常,马上降为</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">1.0V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">。此时电视不能二次开机,一会屏幕亮后(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">41</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">SCL</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">时钟线电压为</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">4.0V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">正常,测</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CN600</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">排线(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">3</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脚)中间电压为</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">18V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">逐渐下降为</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">14V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">。经查为</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CN600</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">排线座漏电,内部已经发绿,(主板上至尾板排线,尾板为分立元件),</SPAN><FONT face="Times New Roman"> </FONT><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">换</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CN600</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">排线座后,不开机故障排除了。开机后屏幕出现灰白屏,无雪花点,一会雪花点逐渐增多行不同步,逐渐至正常。用示波器测</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">IC203<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>CD4052 </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">5</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚有信号,(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">4</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚无信号逐渐有信号渐渐信号变大至正常。第二天再次检查时,测(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">9</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚(制式转换控制脚)电压正常,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">16</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脚供电电压</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">8V</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">正常。断开</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">IC203<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>CD4052 </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">5</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚和</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CPU</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">9</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚(制式转换控制脚)及外围电路后,测轻微漏电。第二天再测漏电严重许多,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">IC203<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>CD4052 </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">5</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚和</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CPU</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">9</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚跨越很长距离,中间只有</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">R079</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">100K</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)和</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">R080</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">100</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">欧),采取空中飞线方式将</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">R079</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">和</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">R080</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">对应串在电路中,连接</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">IC203<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>CD4052 </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">5</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚和</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">CPU</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">9</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">10</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)脚。经此改动后故障排除。</SPAN></FONT></P>
1174 小时
2006-5-6
2021-6-10
热心会员常驻会员资深会员勋章
 楼主| 发表于 2008-3-11 12:48 | 显示全部楼层
抱歉导入论坛搞错了题目
GMT+8, 2025-10-25 06:27
