楼主 |
发表于 2016-10-18 23:11
显示全部楼层
所有发现这个二极管快恢复二极管RF101L4S码88
RF101L4S.pdf
(299.98 KB, 下载次数: 8)
谢谢大家!大家谁在搜索二极管的帮我,做了一个替代的UF4004
更多信息
B0ECKP000055 DIOD1 ROHM,RF101L4S 400V 1A SHORT
B0ACCJ000048 DIOD1 MA2J11100L开关二极管80V 100毫安?
C0ZBZ0001708 IC1 M81737FP
C0JBAU000088 IC1 PAVCTH C541缓冲IC
B1HFPFA00001晶体管1 CPH5524-TL-E
B1JADN000009晶体管1 GT30F125
B1ABCF000231晶体管12PD601ART,215,2SD0601A0L
D0GF5R6JA047中号5.6 OHM,J,1/3W
D0GD100JA059 M 10 OHM,J,1 / 4W1
D16451 B0ECKP000055 DIODE 1 ROHM , RF101L4S 400V 1A SHORT
D16482 B0FACP000003 DIODE 1 RFN25TM4SWSHORT
Q16452 B1JAEP000012 TRANSISTOR 1 GT45G128SHORT
D16702 B0ACCJ000048 DIODE 1 MA2J11100L 80v 100ma switching diode?
IC16521 C0ZBZ0001708 IC 1 M81737FP
IC16561 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
IC16562 C0JBAU000088 IC 1 PAVCTH c541 buffer ic
IC16563 C0JBAB000916 IC 1 c14 INVERTER
IC16691 C0JBAC000363 IC 1 TC7SH00FU(TE85L,J
IC16724 C0CBADE00049 IC 1 BA178M05FP-E2
IC16771 C0CBADC00072 IC 1 78L05L, TA78L05F
IC16773 C0JBAB000715 IC 1 Toshiba TC7SH14F, marking HA, Schmitt NOT
PC16461 B3PBE0000054 IC 1 PS9856-2-F3-AX
Q16402 DG3D5020CSLW TRANSISTOR 1 DG3D5020
Q16403 DG3D5020CSLW TRANSISTOR 1 DG3D5020
Q16421 DG3D4020CSRP TRANSISTOR 1 DG3D4020
Q16422 DG3D4020CSRP TRANSISTOR 1 DG3D4020
Q16521 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
Q16551 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
Q16621 B1JADN000009 TRANSISTOR 1 GT30F125
Q16622 B1JADN000009 TRANSISTOR 1 GT30F125
Q16647 B1CBGD000001 FET 1 2SK3018T106,2n7002
Q16661 B1JAER000010 TRANSISTOR 1 RJP63F3A
Q16701 B1ADCN000007 TRANSISTOR 1 MMBTA92
Q16702 B1ABCF000231 TRANSISTOR 1 2PD601ART,215, 2SD0601A0L
Q16818 B1CBGD000001 FET 1 2SK3018T106,2n7002
R16452 D0GF5R6JA047 M 5.6 OHM,J, 1/3W
R16521 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
R16522 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
R16551 D0GD100JA059 M 10 OHM,J,1/4W 1
R16707 ERJ6GEYG392 M 3.9KOHM,J,1/8W 1
